Selection Problem (Bug?)
Hi @fsalla,
To produce this,
Step 1: Click one door
Step 2: Click any other door
The result shown in the image.
This problem also occurs when I use other architectural elements.
ARQ version : Newest WIP
ARQ
@anon66739973, I can’t reproduce this error, unfortunately. Please run the vaAbout command and attach the screenshot so I can see exactly which VA version you are you running.
Does this issue happen everytime you run VisualARQ? for all documents?
I tested this with different version (1.9+ and 2.0), WIN 10 behaves normal.
Not a big issue if it’s not the software problem.
I faced the same problem. It seems to be somehow connected with Windows 7 visual effects. I found two solutions:
A. Go to: Control Panel / System / Advanced system settings / Visual Effects,
under Custom: uncheck the box “Enable desktop composition”, and the problem seems to be gone;
or:
B. Simply switching to “Windows 7 Basic” or “Windows Classic” theme also solves the problem.
