CeliaNE
(Celia NE)
January 9, 2024, 9:32pm
1
I have a number of breps made from extruding surfaces. Now I would like to select only the lateral / side-surfaces, without the upper and lower surfaces. How can I achieve this? Or is there another possibility, for example to extrude only the curves instead of the surface?
Select specific faces.gh (18.1 KB)
CeliaNE
(Celia NE)
January 9, 2024, 9:55pm
3
Thanks, but the breps on the side should also be like the breps at the top (the blue area in the photo).
There I also need the lateral Faces. How does that work?
It’s your art project, make it so. Perhaps I was too aggressive rounding off the DProd (Dot Product) output?
CeliaNE
(Celia NE)
January 9, 2024, 10:16pm
5
The faces from the breps in the orange area should be like the breps in the blue area. There you deleted the large bottom and cover faces.
Sorry, I don’t understand your images and objectives. This is a variation of the first try:
Select specific faces_2024Jan9b.gh (16.6 KB)
CeliaNE
(Celia NE)
January 9, 2024, 10:23pm
7
On the sides the red faces should be deleted.
The Breps should look like this everywhere.
So… what are the criteria for culling additional faces? Maybe this?
Select specific faces_2024Jan9c.gh (21.2 KB)
Sorry, I’m not interested in pursuing this further. Good luck.
Rajeev2
(Rajeev)
January 10, 2024, 4:33am
9
Select specific faces_a.gh (14.1 KB)
Plugin used Wombatgh
Rajeev2
(Rajeev)
January 10, 2024, 4:53am
10
CeliaNE
(Celia NE)
January 11, 2024, 10:13am
11
Thank you! How can I delete only the faces that are on the wall?
CeliaNE
(Celia NE)
January 11, 2024, 10:24am
13
The faces of the inside, i have tried to illustrate it in the following pictures
CeliaNE
(Celia NE)
January 11, 2024, 10:52am
15
So trimming the Breps with the wall?
CeliaNE
(Celia NE)
January 11, 2024, 10:55am
16
I need the top faces, that i have 5 from 6 faces (the side shapes and the top ones). Can i cap one side?
Rajeev2
(Rajeev)
January 11, 2024, 12:07pm
17
take the top edges and use boundary surface it should give u the top face covered
