Selecting Brep Edges
I would like to select all the curves that are not facing an additional curve in an offest (I hope it is a good explanation). In other words, I would like to select all the curves that have no curves in the same direction to them on their specific XY plane. I’ve attached a screenshot marking some examples.
I tried to do so by selecting only the curves that rest on XY planes. Afterwards I thought to search for the distance between each curve to all of the curves in the same plane (by sorting them through z value) and then eliminating those with a certain distance.
I have attached my attempt with rhino and gh files, would really appreciate some help!
Yoav
190716_Pick by Edge.3dm (2.6 MB) 190716_Selecting Brep Edges_YC_WIP.gh (8.5 KB)
I assume that you speak some language since you post your thread here. If is C# see the attached:
BrepEdges_ClassQuery_EntryLevel_V1.3dm (210.1 KB) BrepEdges_ClassQuery_EntryLevel_V1.gh (117.7 KB)
That said I can’t read your file (I don’t use R6) but the classic way to find things is to use a class that samples related information and then do a LINQ/L query. For the demo query included is very simple:
So based on the above, write any query you like (and if required add stuff in the EdgeInfo class).
Hi Peter,
Sorry for the late reply and thanks for this.
It’s a good exercise, I’ll have a go at it.
Thank you!
This is more elaborated.
BrepEdges_ClassQuery_EntryLevel_V1A.3dm (621.6 KB) BrepEdges_ClassQuery_EntryLevel_V1A.gh (126.6 KB)
