Select sub-objects by display color
How is it possible to select all faces with specific color? The basic command only cares of objects disregarding subobjects.
I want to know areas to different colors assigned…
Thanks
Hi Juan - as far as I can see you are correct that is not possible now -
RH-67980 SelColor: Select sub objects
thank you. now i have to think of different way how to calculate ma areas. probably explode and save as other file
Hi Juan - for now, materials can help - SelMaterialName pays attention to the selection filter setting for subobjects:
