…where a, b, c are sub-layers of 1 and 2 respectively.
I need a way to selet all sub-layers with the same name at once, to then click on the hide/show/lock buttons, as I have 1-10 (parent layers). I.e. select all ‘a’ or all ‘b’, etc.
That will select the objects on the layers; I think the idea is to select the layers in the layer dialog, and I do not see a way to do that. Wait @DuncanW - you do that first, what Mitch says, and then in the Tools menu (hammer icon) in the layer dialog, choose “Select object layer”
I can’t seem to get that to work. I enter -SelLayer …and the moment I hit the spacebar to follow with *-a, it already executes the command of course.
It then offers “Pick” and asks for objects, which is not what I need. I need to highlight all sub-layers with the same name across various parent layers, to then quickly turn them on/off.
All objects on layers whose names end in “-a” should select
Go to the layer panel, hit the hammer (rightmost) icon in the top bar
Choose “Select object layer”
Just *les should work. * is a wildcard. The dash is not part of the wildcard, so it is looking for something that ends in “-les” which “Angles” does not.
Also xx* will find anything that starts with xx *xx* will find anything that contains xx
I think the misunderstanding comes from you calling your sub-layers “-a” and “-b” etc. in the original post. Like Mitch said, the dash is not part of the command - @Helvetosaur just put it there, because that’s what you called your layers in the original post.
