Hi all,
this command only selects connected control points, isn’t there a
similar command for non-control points they travel on the same axis?
Hi all,
Can you show an example of what you are wanting?—-Mark
Sorry if I wasn’t clear, I’ll try to explain myself better. typical example: I select a point and then choose a direction “X or Y or Z axis” and all the points are selected with the chosen coordinate, identical to the selected point.
(I hope it’s clear now, making an outline was more difficult for me than writing)
Is this something you do, or something you want to do?
Rhino does not have a tool that does this, btw.
Perhaps more information on what you want to and why (big picture) would help?
Thanks,
– Dale
Hi Dale,
I asked before, since I had tried to create scripts in Py or def in Gh a few times only to discover that there was already a native command in Rhino that did the same thing. in this case since select points control is very similar to what I would like, I was hopeful that there would be some sort of command, even for a series of “non-control” points that have a single identical direction
I created a def in Gh to better manage when there are a lot of points,
but in some cases I would like to stay in Rhino for practicality.
a simple example to imagine and like a situation like this: a graph with many peaks, each peak determines a point.
if the points are in the middle of other objects, it becomes convoluted to select them without a suitable code for this operation
As soon as I can I’ll try to write down some code to do this
using sy = System;
using rh = Rhino;
new MyScript().Main();
class MyScript
rh.RhinoDoc doc = rh.RhinoDoc.ActiveDoc;
public void Main()
sy.Console.WriteLine( Punto() );
public rh.Commands.Result Punto()
var pt = new rh.Input.Custom.GetObject { GeometryFilter = rh.DocObjects.ObjectType.Point };
pt.SetCommandPrompt("GetPoint");
pt.Get();
var xyz = new rh.Input.Custom.GetString();
xyz.SetCommandPrompt("GetCoordinate");
xyz.AddOption("X");
xyz.AddOption("Y");
xyz.AddOption("Z");
xyz.Get();
sy.Console.WriteLine(xyz.Option().LocalName);
foreach ( rh.DocObjects.RhinoObject item in doc.Objects.FindByObjectType( rh.DocObjects.ObjectType.Point ) )
var ptt = item.Geometry as rh.Geometry.Point;
if (ptt.Location.X == pt.Object(0).Point().Location.X)
item.Select(true);
return rh.Commands.Result.Success;
I tried with this script of mine,
which works in the first part of the selection,
now I’m trying to add a variable to choose the Coordinate via command line, but obviously in this case it returns to me as a string and this is not good.
ps I would like to find a solution as an example given by me
avoiding using the conditional function with IF (xyz==X or Y or Z)
it is feasible?
thanks @dale ,
class MyScript
public void Main()
sy.Console.WriteLine( Pnt() );
public rh.Commands.Result Pnt()
pt.SetCommandPrompt( "GetPoint" );
pt.Get();
xyz.SetCommandPrompt( "GetCoordinate" );
xyz.AddOption( "X" );
xyz.AddOption( "Y" );
xyz.AddOption( "Z" );
xyz.Get();
double[] lst = { pt.Object(0).Point().Location.X, pt.Object(0).Point().Location.Y, pt.Object(0).Point().Location.Z };
foreach ( var item in doc.Objects.FindByObjectType( rh.DocObjects.ObjectType.Point ) )
if ( ptt.Location.X == lst[ xyz.Option().Index - 1 ] )
item.Select( true );
I would prefer a solution like this, without using IF
I’m just having trouble how to combine two different values/objects, I was trying to concatenate them
as texts and convert everything like: Convert.Geometry.Point(“ptt”+“Location.X”) but I don’t know how.
sorry for the crazy question:
pt.Object(0).Point().Location.X //as objref as Point as Point3d as double
if I have a reference/object that contains a 3d point
and which in turn retrieves a coordinate and therefore a double value.
"pt.Object(0).Point().Location.X" //as string
being that the reference string is correct,
if that code string is obtained by manipulating text
can’t I convert the text to the object reference itself?
ps: Maybe you should do all the steps one at a time. . .
(objref)"pt.Object(0)".(Point)"Point()".(Point3d)"Location".(double)"X"
Hi @0904,
I have no idea what you are trying to do - sorry.
However, you can use Point3d as if it were an array.
var point = objref.Point().Location;
for (var i = 0; i < 3; i++)
var component = point[i];
// todo...
Perhaps this is of interest to you.
– dale
using sy = System;
using rh = Rhino;
class MyScript
public void Main()
var pt1 = new rh.Input.Custom.GetObject { GeometryFilter = rh.DocObjects.ObjectType.Point };
pt1.SetCommandPrompt( "GetPoint" );
pt1.Get();
xyz.Get();
double[] lst1 = { pt1.Object(0).Point().Location.X, pt1.Object(0).Point().Location.Y, pt1.Object(0).Point().Location.Z };
var pt2 = item.Geometry as rh.Geometry.Point;
double[] lst2 = { pt2.Location.X, pt2.Location.Y, pt2.Location.Z };
var val1 = lst1[ xyz.Option().Index - 1 ];
var val2 = lst2[ xyz.Option().Index - 1 ];
if ( val1 == val2 && sy.Math.Abs( val1 - val2 ) <= rh.RhinoMath.ZeroTolerance )
I had gone a little astray,
but it seems to work fine this way.
