How to select multiple object control points cumulatively(?)
Is there a way to select another set of control points using a comand (like Select UV), without clearing the already selected control points from the current obejct, or from another?
The same way you can just press “shift” to add an object to the current selection.
The only way I could find was to create a Named Selection and add to it each time.
I’m wondering is there is a better way to do it, or a way to not clear the current control point selection each time.
Shift.
You can add selection of control points cumulatively with shift.
Aren’t you able to do so??
You can select rows of control points by double-click in the control polygon. And you can select first and last control points and then double-click the control polygon anywhere in between to “fill” the selection.
selection
:man_facepalming:
old habits die hard, I do that ALL THE TIME with SubD, never occured to me to do it with srf ctrl pts. Shame on me, yhank you Riccardo!
