Hi, I am working on a file with a pretty complicated layer structure… is there a way to map the “sel objects Layer” in the layer window to a key or so to speed up the process of selecting a layer of a selected object?
manually it takes too long IMHO
thanks
Andreas
Hi Andreas - for now, in V7 you can use this script, on an alias:
HighlightLayers.py (683 Bytes)
V8/WIP has HighlightObjectLayers
To use the Python script use RunPythonScript, or a macro:
RunPythonScript
_-RunPythonScript "Full path to py file inside double-quotes"
Thanks Pascal!
