Select objects by object type "picture surface"
I can’t find the command to select objects by object type.
In the manual, there is just the title but no the related text.
Edit > Select Objects >
Or there’s a selection filter at the bottom of the screen next to Osnap tab.
Hi @Lay
All the commands listed below the headline (Select by object type) are the different variations of selection commands meant for selecting by object type. This includes different types/variations of surfaces, polysurfaces, lines, curves, various helper objects (eg. clipping planes) etc. Are you looking to achieve some particular selection or just going through the manual?
HTH, Jakob
I am trying to select all objects with the type “picture surface”.
Hi @Lay
SelPicture should do that.
-Jakob
It did, thanks !
