Select Name
Is there a way to make named parts appear in alphabetical or numerical order when searching by name…?
What I am getting now is of little use. Especially since my model eventually will have around 1000 pieces. I’ve never used this feature before…
Darius
SelectName
Hi Darius - thanks, I’ll add that to the heap. It should be easy to make a script in the meantime to sort those, I’ll take a look. Alphabetical looks correct, the numbers not…
@AdamBBLee Here’s a Python that may get it right…
SelNameEx.py (680 Bytes)
Use
! _-RunPythonSctript "Full path to py file inside double quotes"
to run it… Or just RunPythonScript
https://mcneel.myjetbrains.com/youtrack/issue/RH-44460
Well in this case I’m going back to what proven and tested; layers and sublayers. Thanks Pascal.
Darius
The numbers are sorted alphabetically too, since the names are just strings. That is why “12” comes before “2”.
Thanks, I can see it but in my case it won’t work. I would need them to be sorted by numerical order only.
Darius
RH-44460 is fixed in the latest WIP
Awesome! I remember writing about that issue in another topic long time ago. Glad to see that the natural order of object names is implemented now. :slight_smile:
Haven’t test it yet but thank you for fixing it.
