Select Multiple objects with Grasshopper Component
Hi guys,
I think this should be an easy answer, When I’m writing a script in Grasshopper I can insert a tekla beam object and select multiple beam, but when I run that script through the Grasshopper Component in tekla I can only pick 1 beam.
Any sugestions welcome.
Regards Greg
Put “M:" At the beginning of the name of the beam component and it will prompt you to select multiple (up to 99).
Thanks Oskar.
I knew it would be simple.
Is there a help file that would have guided me to that solution ?
Here you go mate!
Thanks Oskar, yet again you’ve made my life wonderful :slight_smile:
You’re welcome :rofl:
