data paths permutations.gh (20.1 KB)
My question is whether this is possible without using Python and how it’s done. The idea is to have a tree with multiple paths as items where each branch has a permutation of all possible paths minus the current one. From those I want to select paths from another tree. In the other tree are branches with single or multiple items so the result tree should have a sublist. For example all paths with 0 or 1 items should end with “;0” while the ones with multiple items should end with the corresponding item index. Gemini did the python script.
python
import Grasshopper
from Grasshopper.Kernel.Data import GH_Path
from Grasshopper import DataTree
# Fixed: ‘object’ as a type inside brackets, followed by instantiation parentheses ()
output_tree = DataTree[object]()
if Paths is not None and Data is not None:
print("Processing {} paths branches...".format(Paths.BranchCount))
for i in range(Paths.BranchCount):
try:
target_path = Paths.Path(i)
except:
target_path = Paths.Key(i)
branch_paths = Paths.Branch(i)
for p in branch_paths:
try:
\# Clean and parse the path value safely
if hasattr(p, "Indices"):
gh_p = GH_Path(\*p.Indices)
else:
clean_str = str(p).strip("{}\[\]() ")
if ";" in clean_str:
parts = \[int(x) for x in clean_str.split(";")\]
elif "," in clean_str:
parts = \[int(x) for x in clean_str.split(",")\]
else:
parts = \[int(clean_str)\]
gh_p = GH_Path(\*parts)
\# Directly try fetching the branch items
source_items = Data.Branch(gh_p)
if source_items:
for item in source_items:
output_tree.Add(item, target_path)
except Exception as ex:
pass
a = output_tree
Thank you in advance!
