Select Group Code Only
Is there a way to select a group by name with code only. I do not want to pick from a dialogue box. I have the names and want to select with python code only.
Thanks
Eric
Hi @eric.bunn, you might try below:
import Rhino
import scriptcontext
def SelGroupName(group_name=None):
    group = scriptcontext.doc.Groups.FindName(group_name)
    if not group: return
    for rh_obj in scriptcontext.doc.Groups.GroupMembers(group.Index):
        if rh_obj.IsSelectable(): rh_obj.Select(True, True)
    scriptcontext.doc.Views.Redraw()
SelGroupName("Group03")
_
c.
I should have mentioned that I am running Rhino 5. I’m getting this error when I run the script:
Message: ‘GroupTable’ object has no attribute ‘FindName’
Traceback:
line 8, in SelGroupName, “C:\Temp\TempScript.py”
line 16, in , “C:\Temp\TempScript.py”
Thanks,
Eric
Well, if you are willing to use rhinoscriptsyntax and you know the group name, you can use simply:
objs=rs.ObjectsByGroup(groupname,True)
I’ll try that. Thank you.
Eric.
This worked for me thanks.
