It would be nice to be able to use the SelBoundary with in other commands. For instance if I am using a Boolean difference command I am trying to select a bunch of cutting elements.
Yeah, that should work - it goes through the motions but nothing gets selected, in BooleanDifference, but it does work inside other commands, like say Trim. For now I made a bug report specifically for BD, but that may turn out to be only step 1…
thanks for the report.
Yeah it looks like all the transforming tools move, copy, rotate, shear, twist ect… it works on. But doesn’t work on any of the Boolean commands.
