SelBlockInstanceNamed papercut - enter to confirm
Hi McNeel
Would it be possible to change the SelBlockInstanceNamed dialog box, so that if I run the command, select a block (or several blocks) and press Enter, it will execute the command? Now it cancels the command instead of running it, and I just think it would make more sense to be able to select a block from the list and immediately run the command by pressing Enter instead of having to move the mouse down to the OK box.
TIA, Jakob
