V5
I have a circular set of objects and wish to do a sectioned view bending at 90 deg at centre , the result being a ‘cake with a slice missing’ and another a straight section and the result to hatch the cut faces, or an option to paint them red as in museums !
Keeping the objects colours in the process.
The result to be like a museum exhibit. seeing the solid beyond the section.
As an option, can the sectional line take a meandering path through the object to display certain key features ?
see attached item.
Can also the section start within the drum surface area , perhaps not I reckon.
This took some time for this to paste into a new file, it came from my slow file yet why does it bring with it the slowness ?
At 1Mb is that expected for a few objects ?
sectional methods.3dm (946.4 KB)
I thought I had solved it, installed SectionTools from Food4Rhino but cannoet see an L sction option or more.
Surely there has to be a way in Rhino for doing a bent section ?
Steve
