Secret history supported commands?
well, I was lucky that _BooleanIntersection supports history, although it is not listed in the help. Now I wonder what other functions can be used with History, although they are not documented. Are there more?
It would be nice if the list could be updated to all commands.
I’m so glad that _BooleanIntersection works for history, since it allow to use (also to animate per Bongo) particular clipping of selected objects of a scene. :slight_smile:
-Micha
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/history.htm?Highlight=history
@Micha
Sorry, I forgot to update the list when history support added to some commands. I’ll find all the commands missing on the list. DOC-329
Hi Micha -
Note that while the list isn’t updated yet, you were looking at the Rhino 7 help file, not the Rhino 8 help file. The list in the link that you provided (Rhino 7) is complete, and the Rhino 8 list is expected to be complete before Rhino 8 ships.
For my work I can use Rhino 7 only, because Rhino 8 is still to bugy. I can’t see _BooleanIntersection at the Rhino 7 History help page. Where do you see it?
Hi Micha -
You’re correct. I was looking at BooleanDifference…
Thanks,
@Micha
https://docs.mcneel.com/rhino/8/help/en-us/index.htm#commands/history.htm
I updated the list in the History topic in v7 and v8 to include all the commands that support History.
Thanks for finding out the mistake.
Hi @KelvinC ,
Can you please check/confirm that IntersectTwoSets is also History Enabled in Rhino 7? It doesn’t appear on your list but is very definitely working in my build, Rhino 7 SR37 (you’re making me nervous because if it suddenly stopped working one day, it would screw up quite a few of my files). Thanks in advance.
@Jack_Brown
I cannot find any issue in the tracking system talking about history support of the IntersectTwoSects command. It could be added when History support was added to the Intersect command. I’m updating the topics. Thank you.
@Jack_Brown
Updated. Thanks.
Thanks Kelvin.
