Command History - No Commands
Command History does not include the commands which have been executed. Is this a bug or some setting I inadvertently changed? An example of what I’m seeing:
1 open surface added to selection.
v
0
34.9
v
0
55.8
3 surfaces added to selection.
HorizCenter
0
3 objects changed to layer “Vertical”.
'_Zoom
_All
_Extents
n
1 point added to selection.
Found 1 duplicate. 1 point added to selection.
Duplicate selection is from model space only.
Creating meshes… Press Esc to cancel
Rhino 7 SR17 2022-3-10 (Rhino 7, 7.17.22069.03001, Git hash:master @ 04f6e9ffab44f423581e5ca6c790328fa62b4f08)
License type: Commercial, build 2022-03-10
License details: Cloud Zoo
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 12-29-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.09
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-29-2021
Driver Version: 30.0.15.1109
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.17.22069.3001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.17.22069.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.17.22069.3001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.17.22069.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.17.22069.3001
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.21.831\SectionTools.rhp “SectionTools”
Hi David - are the single letters aliases that you have set up to run commands or command options for the invisivble commands?
Found the cause and fixed it.
In Options > Advanced Rhino.Options.Appearance.EchoCommandsToHistory was False. I set it to true and Command History is functioning as expected.
I have no idea how that setting was changed. I have not been into Options for several weeks, and then no where near that option, and this problem only started today.
Options for the invisible commands. See note above about solution to problem.
