This topic arises from a very minor frustration with GH when searching for the “scribble” component.
Sequence:
- I want to a add a comment on the document
- I double click on the document to have a search window (I had forgotten that to put comment on a document, you need the “scribble” component)
- I enter “comment” then “note”
Problem:
- the scribble component does not appear
Note:
- Since I am used to other modeling tools, I was searching for note or comment (UML standard, for instance, has a “Comment” item).
Proposed solution:
Could it be possible to have the “scribble” component be proposed when one search for “note” or “comment” in the keyword search ?
