My latest install says this and scripts don’t run. How do I fix it?
Yes I did
@phcreates Would you mind confirming that the file application.py exists under this path?
C:\Users\phcre\AppData\Roaming\McNeel\Rhinoceros\9.0\Plug-ins\IronPython (*) settings\lib\rhinoscript\application.py
It would be nice if you can share a screenshot of this folder contents
Installing the new WIP today fixed the problem (and the application.py file is restored.)
Perfect. For some unknown reason this file was missing. Usually manually deleting the IronPython plugin folder and relaunching Rhino forces the plugin to recreate this folder and files, fixing missing file problems.
