I’ve made a macro in Excel that writes a script for Rhino into a .txt file. Now I need to make a script in Rhino that ask you where is located the .txt file, open it, and read the script inside the .txt file and run it. Is this posible to do? If it is, how could I do it? I mean, wich commands should I use in order to make a script that runs the script inside the .txt file? Thank you a lot.
I’ve used the “Rhino.OpenFileName” and “Rhino.ReadTextFile” commands. The first open a window where you can select the file with the script (now my script is written into a .rvb text file). The second command is supposed to read the content of this file and to store it. But I still don’t know how could I run the script that I have selected. Do anyone knows it? Thank you a lot
I tried the command you told me but it doesn’t recognize it as a command (my versión is Rhino 5). What I would like to do is to make a script that runs other script for rhino that has been previously wroten by a macro of Excel into a .rvb text file, it’s a bit difficult for me to explain it because English is not my mother language ha ha
Thank you jordy, it works, but only if I write it into the command window of Rhino. The thing is that I would like to make the same thing in a script, I mean, writting it into the script editor of Rhino
[quote=“Charly, post:6, topic:28332, full:true”]
I tried the command you told me but it doesn’t recognize it as a command (my versión is Rhino 5).[/quote] ReadCommandFile is a rhino5 command.
