Hi everybody!
I’m serching a way to edit a new button so that the command run a script but it seems to not work anyway…
can someone help me?
thks a lot,
Marco
Hi marco- for RhinoScipt the macro to use will be something like one of these:
! _-Runscript (
full script text in here
! _-Runscript "Path to script file in double quotes"
! --Runscript ("name of script subroutine")
What to use depends upon how the script is designed - do you have an example script?
For a Python script use ! _-RunPythonScript ( "Path to scriptFile.py)
Any of that work?
Hi Pascal!
here I copy the text of the script:
Option Explicit
Call Main()
Sub Main()
Dim strSrf, arrPt, arrParam, arrNormal, arrScale, arrAdd
strSrf = Rhino.GetObject("select srf", 8, True, False)
If IsNull(strSrf) Then Exit Sub
arrPt = Rhino.GetPointOnSurface(strSrf)
If IsNull(arrPt) Then Exit Sub
' get surface uv parameter at this point
arrParam = Rhino.SurfaceClosestPoint(strSrf, arrPt)
' get surface normal vector at this paramter
arrNormal = Rhino.SurfaceNormal(strSrf, arrParam)
' scale normal vector to desired line length eg. 10.0
arrScale = Rhino.VectorScale(arrNormal, 10.0)
' add scaled vector to point on surface
arrAdd = Rhino.VectorAdd(arrScale, arrPt)
' create line between both points
Call Rhino.AddLine(arrPt, arrAdd)
End Sub
so to insert in a command of a new button It’s correct so:
! _-Runscipt (Option Explicit
Call Main()
Sub Main()
End Sub)
thks,
Marco
but in this way It seems to not work…
Hi Marco - yes, but is
! _-Runscript
, and not ! _-Runscipt
as I wrote… I’ll fix my post, sorry.
Perfect! you are Great!
