I don’t think I should be getting the first one anyway!
Also when I upgraded to version 6.8.1820.20051 I got this RhinoDotNet error. (I’ve been getting the popups before and after the upgrade.)
Hi, That RhinoDotNetCrash.txt file error will be fixed in 6.9. Feel free to delete that file whenever you see it.
Also, it looks like, somehow, your computer is set up to run “C:\Users\Public\Documents\Rhino6\Rhino6CU.reg” every time Rhino starts. Probably the simplest thing to do is to delete that file.
Another thing to do is to search your registry for that filename:
From the start menu in Windows, type RegEdit and press Enter.
From the Edit menu, click Search then search for C:\Users\Public\Documents\Rhino6\Rhino6CU.reg
When you find it, please take a screen shot of your registry editor and post it here.
My guess is that we’ll just need to delete a registry key that tells Windows to run this.
Hi Brian,
First thing I tried was to rename the file Rhino6CU.reg, but the popup still popped when I restarted.
Then I searched the Registry for that file path and came up with nothing.
What does that file do?
I wonder if it is a script that the university IT guys put in to direct Rhino to the license server? Although it doesn’t seem to make a difference whether it runs or not.
