Script Editor won't open and Python3 not working in Grasshopper
We have the following issue.
We have Rhino 8 and Rhino WIP (9.0.26027.12305) installed.
When placing a python component on an empty canvas in Grasshopper we get this error:
“An exception was thrown during a solution”
When clicking ok the component looks like this
Note that this works perfectly in Rhino 8.
We tried opening the script editor and got this message in the command line:
_-ScriptEditor
Select Option ( Edit  Run  Open  Test ): _Edit
Error opening script editor form | System.Text.Json.JsonReaderException: The input does not contain any JSON tokens. Expected the input to start with a valid JSON token, when isFinalBlock is true. LineNumber: 0 | BytePositionInLine: 0.
   at System.Text.Json.ThrowHelper.ThrowJsonReaderException(Utf8JsonReader& json, ExceptionResource resource, Byte nextByte, ReadOnlySpan`1 bytes)
   at System.Text.Json.Utf8JsonReader.Read()
   at System.Text.Json.JsonDocument.Parse(ReadOnlySpan`1 utf8JsonSpan, JsonReaderOptions readerOptions, MetadataDb& database, StackRowStack& stack)
   at System.Text.Json.JsonDocument.Parse(ReadOnlyMemory`1 utf8Json, JsonReaderOptions readerOptions, Byte[] extraRentedArrayPoolBytes, PooledByteBufferWriter extraPooledByteBufferWriter)
   at System.Text.Json.JsonDocument.Parse(ReadOnlyMemory`1 json, JsonDocumentOptions options)
   at System.Text.Json.JsonDocument.Parse(String json, JsonDocumentOptions options)
   at Rhino.Runtime.Code.Serialization.Json.JsonStreamReader.ReadJson(String json)
   at Rhino.Runtime.Code.Serialization.Json.JsonStreamReader..ctor(String json, JsonSerializerOptions options)
   at Rhino.Runtime.Code.Serialization.Json.JsonStream.GetReader(String json, JsonSerializerOptions options)
   at RhinoCodeEditor.Aspects.MainEditorState`1.TryFindLegacy(JsonStreamReader& reader, PersistentConfigsSchema& schema)
   at RhinoCodeEditor.Aspects.MainEditorState`1.TryLoadAsync(TEditor editor)
   at RhinoCodePlugin.Commands.ScriptEditorCommand.TryOpenEditorFormAsync(Form owner)
Note that if we use the EditPythonScript command we get to the python script editor just fine, and python works there as expected.
What we tried:
Uninstall Rhino WIP and reinstall. Issue persists.
Restart computer. Issue persists
Remove Grassshopper components both via the compnents folder and via the packagemanager. Issue persists.
This is only on a single computer.
Here is the SystemInfo from a computer where it works.
Rhino 9 SR0 2026-1-27 (Rhino WIP, 9.0.26027.12305, Git hash:master @ 5f15e63747872f59c771ecf3d824aa18e045777a)
License type: Commercial, build 2026-01-27
License details: Cloud Zoo
Expires on: 2026-03-13
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET 9.0.3
Computer platform: LAPTOP  - Plugged in [99% battery remaining]
Hybrid graphics configuration using DirectX
  Primary display: NVIDIA RTX 2000 Ada Generation Laptop GPU (NVidia) Memory: 8GB, Driver date: 10-12-2025 (M-D-Y).
        - Laptop's primary display device
Secondary graphics devices.
  Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 9-12-2025 (M-D-Y).
        - Windows Main Display is laptop's integrated screen or built-in port
DirectX Settings
  Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
  C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp	"Commands"	9.0.26027.12305
  C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp	"UpdatesAndStatistics"	9.0.26027.12305
  C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	9.0.26027.12305
  C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	9.0.26027.12305
  C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp	"MeshCommands"	9.0.26027.12305
  C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	9.0.26027.12305
  C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp	"Displacement"
  C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp	"SectionTools"
And here is the system info for the computer where it DOESN’T work
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 64GB)
.NET 9.0.1
Computer platform: LAPTOP  - Plugged in [100% battery remaining]
    > Integrated accelerated graphics device (shares primary device ports)
  Intel(R) Arc(TM) Pro Graphics (Intel) Memory: 2GB, Driver date: 2-26-2025 (M-D-Y).
DirectX Settings
  Safe mode: Off
The system info was pulled before deleting grasshopper plugins
Hi Timo,
Lets completely reset the python environment by closing Rhino and deleting %HOMEPATH%\.rhinocode and restart Rhino
  • Run ScriptEditor command and let it initialize languages
  • Run RhinoCodeLogs, save the logs into a text file
Hi, I tried these steps a couple of times but haven’t been able to open the ScriptEditor window. I’m using Rhino 8 but also have the 9 WIP installed.
Rhino 8 SR30 2026-3-23 (Rhino 8, 8.30.26082.23001, Git hash:master @ abea9e77e9bb144e00d8281bfa44e613abd9d918)
License type: Commercial, build 2026-03-23
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 24GB)
.NET 8.0.19
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P620 (NVidia) Memory: 2GB, Driver date: 8-7-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 580.97
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port #0
  • Secondary monitor attached to adapter port #1
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-16-2022 (M-D-Y).
Integrated graphics device with 3 adapter port(s)
  • There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-7-2025
Driver Version: 32.0.15.8097
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.30.26082.23001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.30.26082.23001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.30.26082.23001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.30.26082.23001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.30.26082.23001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.30.26082.23001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.30.26082.23001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.30.26082.23001
C:\Program Files\Rhino 8\System\netcore\export_PDF.rhp “PDF Export” 8.30.26082.23001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.30.26082.23001
ScriptEditor.log (30.4 KB)
Hi Keen,
This looks to be an eto version mismatch causing the issue.
Lets go to Add or Remove programs and repair Rhino. (Right click, modify, repair)
yes, that solved it. Thank you.
