Hi I know this is prob a super simple solution with a graph but I have not had any luck with the issue. If I want to make the top of the loft a different size than the bottom, ie I want to offset or scale while I go vertical, How would I do this? Either to go outwards or inwards.
thank you so much, I was just working off a generic shape but I’ll keep that in mind for future reference.
If I wanted to rotate this offset like in my script, I assume I would do that in the step before loft after I offset the geometry.
Also in your blue model there is a relay that is blacked out on the top of the picture, between move > scale I’m curious why you used that instead of plugging the geometry in regularly?
