Grasshopper tower
hi, i need help to realize a tower in grasshopper. As you can see from the photo I need the tower to maintain a straight side and one that decreases going upwards but I don’t know how to achieve it.
i tried to do it whit this gh file but i can’t achieve the straight side
tower twist.gh (13.5 KB)
Hi @Alessio_Perna,
Feed your curves into the Loft component in Grasshopper.
That should give you the mass you seek.
Hope that helps!
but the curves that i have now are not what i want to achieve. because right now the two sides of the shape are decreasing, i need that only one decrease
before rotating each section, instead of scaling each curve on its Centroid, you might scale each curve on a point that belongs to the curve itself:
tower twist_Re.gh (17.6 KB)
