Scale2D or Scale3D with copy and move
I remember when using Scale2D or Scale, there was a way to copy object while moving the first position of the copied object then scale.
So, having a original curve, 1) then copy that object, 1) move it, then 3)scale all in one step.
…as I can’t recall, I’m just copying,moving,then scaling one command at a
time.
Attached file for the topic. white is the original curve, blue is
the copied moved and scaled curve, then sweep2 surface.
Maybe I’m just using the command incorrectly…Question_3DSCALE_COPY.3dm (73.4 KB)
if you use the Orient command with copy and scale 3d options on, it will do what you’re after.
Exactly! Yes! thank you!
