I think there might be a bug with block insertion in a layout.
When I insert a block in a layout, the insertion scale is computed from the model unit instead of the layout unit.
It only works well when model and layout have the same unit.
Hi Baptiste - I see that - I am not completely sure off hand what’s expected there but it does seem at least questionable .
http://mcneel.myjetbrains.com/youtrack/issue/RH-32009
thanks,
Hi Pascal,
I had save multiple details of drawings (2D) in external files to insert them when needed in the model space or in the layout depending on the user habits.
My template was set in centimeters in the model space and in millimeters in layout space. So I noticed that bug when trying the both methods. It’s no big deal but as you said :
