Hi all
Recently when I started using the scale or rotate commands, the object I’m rotating / scaling disappears, and I can no longer estimate what I’m doing with it? Any help?
Hi all
Hi Nico,
Do I interpret it correct that your do not get a preview of the object you are transforming?
If you finish the command, the object is transformed, yet you cannot use the result because you did not get a preview.
Can you run the command SystemInfo and paste the resulting output here?
It can give a clue if your GPU driver might be out of date or apparently incomaptible.
-Willem
Hi Willem
Yes, exactly - no preview while doing transformations.
It had worked perfectly until quite recently.
SystemInfo below:
Rhino 6 SR7 2018-7-29 (Rhino 6, 6.7.18210.11281, Git hash:master @ f815aae129dfe2008152736625ca2dbd0036b29a)
Licence type: Educational, build 2018-07-29
License details: Cloud Zoo. In use by: Nico Jabu Van Loggerenberg ()
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: NICO-ACER-V17
GeForce GTX 1060/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 398.82)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-30-2018
Driver Version: 24.21.13.9882
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.7.18210.11281
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.7.18210.11281
C:\Program Files\Rhino 6\Plug-ins\Import_PDF.rhp “PDFReader”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.7.18210.11281
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.7.18210.11281
Hi Nico - if your objects are very far from the origin, (?) this bug was recently fixed - I think the fix will be in the 6.9 release candidate.
Hi Pascal
They are about 200/300 metres away, not sure at which point the origin becomes a problem?
Hi Nico - that should not be the problem then I’d guess - does it make any difference if you move the objects close to the (world) origin? In other words, does this ever look correct or only in some cases?
It is intermittent - on the exact same files, without moving objects closer to the origin, it sometimes works and sometimes doesn’t.
It happens to basically all my files, and then works again occasionally on a restart. I’ll post an example of a file which it happened to. 2018.08.23 - TRS - Fracture child.3dm (889.6 KB)
Hi Nico - just to be sure - is it the original object that is not showing or the selected/highlighted rotated object? I think I understand it is the latter but just making sure.
Does it make any difference if you change the setting in Options > View > OpenGL > GPU tessellation?
It is that yes. I haven’t had the issue yet this week - it’s really intermittent. Will try post again if it returns.
