Scale and rotate far object (>150000 mm from origin) is not working.
The first pick point (origin) doesn’t seem to be correctly registered.
Hello - can you post an example? Here it works as far as I can see, but I do not get the expected preview.
https://mcneel.myjetbrains.com/youtrack/issue/RH-47723
Effectively the transform is applied correctly.
I need the preview though.
