Sbsar leather has a lot of depth - how do I reduce this?
Hi All,
I’m having some issues (again) with leather materials.
I got some great advice from Kyle, to go down the sbsar route.
I downloaded and added a sbsar to the ring I’ve been designing:
DC Ring - Grey Leather Substance.3dm (837.3 KB)
However, the material doesn’t look like the image on the website:
I’ve played around with the filters/options but it just doesn’t look like the image on the website.
Could anyone help?
I find leather is the most difficult of all the materials to add to objects, is this how people usually feel?
I plan on using fabrics a lot, going forward - so it’s really important for me to get this looking right.
Any help would be massively appreciated,
Ashley
you might want to Unwrap the inner ring, and uncheck the displacement in that texture (Height)
would this be something close to what you are after?:
Hi Gijs - what does this mean? How would I do this?
Yes, what you’ve done here is much closer to the original image, and I thank you for that. But shouldn’t the substance materials be ‘good to go’ from the get go?
what you see on the website, is a piece of cloth that has the correct texture mapping coordinates. The material, wether it is a substance material or not, needs mapping coordinates to apply the textures. In some case, you can get away with OCS/WCS mapping, but in this case it is better to unwrap.
There is an excellent video about Unwrapping textures here, made by @BrianJ :
Gijs - thank you!
I’ll have a watch of it and unwrap.
I have to warn you though, I may have more questions…
Again, thank you.
Ashley
Remember that in your case, leather will also look different. The scale-space of your scene is considerably smaller than a typical scene for leather (furniture, tables, automotive interior, clothing). In effect, depending upon what “real life” leather you chose, you may well end up with a slightly odd looking texture that is physically correct for the scale-space of the scene.
If you chose even softer leathers, you may find that your UV size will (or should) look large, because the ring is only of the order 2 cm in diameter.
