I’ve been unsuccessful in lofting the transformations from triangle to circle on my tetrahedron.
Neither ‘ruled surface’ nor ‘loft’ works as I would expect, and the result is a twisted mess.
What am I doing wrong?
Looks like the circles and triangles are going in opposite directions. I don’t have LunchBox so I didn’t open the file, but you can try flipping the circle direction, or rotating the circles until they align better with the triangles.
Seam alignment is a common loft/ruled surface issue. If you would like, Pufferfish plug-in has an “Align Curve Seams” component that will auto align them for good results.
