I dont understand rs.FlipSurface. I feel like it should return a flipped surface. Is it flipping the surface I pass in? I cant seem to get it to work. @@
Thanks in advance.
Thanks in advance.
Hi Jake,
below seems to work over here if the surface has not been flipped already:
surf = rs.GetObject("Select object", rs.filter.surface)
if surf:
flip = rs.FlipSurface(surf, True)
if it is flipped, i can change its flipped state back using:
flip = rs.FlipSurface(surf, False)
do you see something different ? (Tip: In your display mode, assign a different backface color to quickly see if it worked)
c.
Hi Jake.
Try this:
if (rs.FlipSurface(surf, False)):
pass
else:
EDIT: Again did not refresh the page. I owe you a beer for this Clement.
i love it ! ![]()
The beer?
Thanks
yeah…and the script to toggle the flipped state without knowing it
I see I was trying to make it do something else. I’ll post what I am trying to do in a new post so it will be easier to search. Thanks guys.
