Is there a way to find multiple polysurface showing the reverse and flip them over?
If each object is selected, the command will be used
Flip, Dir
Dim strObject
strObject = Rhino.GetObject("Select a surface to reverse")
If Rhino.IsSurface(strObject) Then
Rhino.ReverseSurface strObject, 1
End If
I think you are looking for FlipSurface(), not ReverseSurface() if you want to flip the surface normals. Unfortunately, the Rhinoscript/rhinoscriptsyntax methods only take single surfaces, not joined Breps (don’t know why though). For polysurfaces I think the only way to be able to do it via a script is either to script the “Flip” command, or work with Python/RhinoCommon Brep.Flip().
Must have some syntax, search for all “backkface”
Do the inverted surfaces show a negative volume? That could be a way to identify them…?
Graham
