Hei how to Flip a surface in vb script ?
Rhino.FlipSurface(srf_id, boolean[optional])
But as this is a fixed function “flipped” or not - it doesn’t just invert the current direction - you also need to check if it’s already flipped, and then if it is, to reverse the direction, you need to “unflip” it.
If Not Rhino.FlipSurface(srf_id) Then
'surface is not flipped, so flip it'
Rhino.FlipSurface(srf_id, True)
Else
'surface is already flipped, so "unflip" it'
Rhino.FlipSurface(srf_id, False)
End If
Thanks a lot
