I’ve used the method in the snippet below to export dxf-files in rhino6 for windows. In RhinoWIP for mac it throws an error: Unknown command: “/Users/username/Documents/untitled_1.dxf”.
It seems the argument is interpreted as a separate command. Can someone help me with this?
Hi David,
thanks for the reply. I get the same error with your snippet. Why do you propose backslashes? Do you suspect system (language) settings related issues?
@DavidLeon Not visible to public…
I think I ran into the same issue this morning. It seemed like the - version of the command still invoked the dialog box.
OK, thanks Wim - geez, 10 months and hasn’t been fixed yet…
So we’re still nowhere with being able to script a batch export of anything in MacRhino regardless of the version. In V5 current, the BrowseForFolder() method is broken so you can’t specify a destination folder for exported files, and in V6 WIP, the export itself is broken…
Why is there no function in rhinoscriptsyntax for exporting or saving an array of objects? To me it seems this funtionality is often used for e.g. batch exports like you mention.
All open, import, saving and export functions via script rely on scripting the “Open”, “Import”, “Save” or “Export” commands. I guess this might be because of the sheer number formats that Rhino can import/export. I think via RhinoCommon you can write out a Rhino .3dm file though, but it’s a bit complex.
Just to note that all this stuff works fine in windows Rhino, it’s just in the Mac versions that it’s broken.
