I tried to write the following script for opening all files from one folder and saving them in an other one.
However, it’s not working and I can’t figure out what I’m doing wrong. Im working with Version 5.3.2
Someone here that can point me to what exactly is wrong with this script?
import os.path
def BatchSaveAs():
folder = rs.BrowseForFolder("/Users/jehrenstein/Desktop/TEST/stp")
if folder: print folder
saveFolder = rs.BrowseForFolder("/Users/jehrenstein/Desktop/TEST/obj")
if saveFolder: print saveFolder
for filename in os.listdir(folder):
if filename.endswith(".stp"):
fullpath = os.path.join(folder,filename).lower()
rs.EnableRedraw(False)
rs.DocumentModified(False)
rs.Command("_-New _None",False)
rs.Command('_-Open {} _Enter'.format(fullpath))
comm="_-Export"
rs.Command(comm + chr(34) + saveFolder + "/" + filename + chr(34) + ".obj" + "_Enter")
rs.EnableRedraw(True)
BatchSaveAs()
I just started with Rhino and Python, so I’m really thankful for any help.
@RIL I’m with emilio, but thanks for your input Rolf! @emilio I added “SelAll” to the commands @jeff_hammond do I even need it, or can I just use the path as string?
import os.path
def BatchSaveAs():
folder = "/Users/jehrenstein/Desktop/TEST/stp"
saveFolder = "/Users/jehrenstein/Desktop/TEST/obj"
rs.Command("_-SelAll")
comm="_-Export"
BatchSaveAs()
that works… it’s using -Import instead of -Open because i don’t think Open is scriptable on Mac but Import is.
so, open a blank file in Rhino and run the script from there… it just imports then deletes when finished instead of opening a new file then closing it.
(oh… the Users/jeff path won’t work… switch it back to your user name )
I’m trying to do something similar on a windows computer.
I successfully cycle through the script but when it comes to the Export (I’ve also tried Save), it prompts me to save the filename as opposed to using the existing filename.
