Hi, I have a polygon and I want to rotate it to a particular plane. Is this possible on Rhino?
The command is not available on Rhinoscriptsyntax, and how do I get the U and V in the AddPlaneSurface
command?
I see, I missed the tag about scripting. In Rhinocommon it is a Transform called ChangeBasis.
Here it is in Rhinoscriptsyntax:
https://developer.rhino3d.com/api/RhinoScriptSyntax/#transformation-XformChangeBasis
https://developer.rhino3d.com/api/RhinoScriptSyntax/#transformation-XformChangeBasis2
You can also do this (assuming you have the plane of the polygon):
xform=rs.XformRotation1(old_plane,new_plane)
transformed=rs.TransformObjects(objs,xform)
