RIR freezes Revit 2025.4 and Rhino 8 SR16 screen with LandsDesign Plugin
Hello all, I updated to the latest version of Rhinoinside Revit and its opening Rhino Sr 16 successfully. Till then everything seems working correctly. Once I open Grasshopper it freezes both Revit 2025.4 and rhino 8 Sr 16. I am unable to use it. I tried disabling all Revit plugins and I found Lands design plugin is creating error. I am attaching a video for reference. kindly help. @ Albert Rodríguez
Hi Asisintel,
thanks for reporting it. We’ll try to reproduce the error.
  • I guess Lands Design loads on a regular Rhino 8 (not inside Revit), right?
  • Was it loading on Revit before you updated Rhino Inside Revit?
Yes @albert Lands design is working in regular Rhino 8. This was working before the updates of RIR last week.
Do we have any update? @albert
No, no news yet
I just tested it and I got Lands Design 6.2 loaded in RhinoInside.Revit:
I’m using the latest versions I found:
  • Revit 2025.4 (25.4.0.32) 20241202_1040(x64)
  • Rhino 8 SR18
  • RhinoInside.Revit 1.29.9186.27799
  • Lands Design 6.2.2.10309
It loaded but I couldn’t work for a long time before it started behaving strangely (command line not responding, a crash…). Is this what you are experiencing?
Yes exactly the same issue
Hi @asisintel Lands Design running inside Revit should work fine since the 6.3 update: Download - RhinoLands
@fsalla Thanks for the update. It works!.
