Hi, let me first say that Rhino+Grasshopper navigation with trackpad is really working nicely now and it is a pleasure to use it on Mac.
I have three questions however, and I don’t know where else to post them.
Is it expected behaviour that right-click (or two finger tap) on a selection of multiple components will only give the options for the single component under the cursor? I was hoping for something akin to the palette appearing that would apply to all selected components. The palette used to be a satisfying hit on the spacebar, but is now (for a while!) inconvenient to access.
CTRL+left click in other applications gives the context menu, but not on Grasshopper components. Could this be made to happen? Or would it break something else?
Click & drag + Option duplicates components, but for some reason not a Scribble. Is this on purpose? It would be nice if that worked the same way.
Two finger tap in between components but within the dotted line selection border when more than one is selected. This is middle click if you use a mouse or stylus no matter where the cursor is but for track pad you need to be between components or off of a single selected component.
I don’t think Ctrl + LMB does anything now on Mac but does the solution to 1 solve this? Cmd is deselect and disconnect on Mac where Ctrl is used for those on Windows so at a guess it might be a cross platform issue if we changed it.
This is great. I even see that it works outside of the selection border. It seems that with this menu, the radial menu (which I above mistakenly called the palette) has become obsolete?
You can still get the radial menu with a middle click but I’m not seeing a way to get the trackpad to do one. It looks like all the same tools are there but it’s not as pretty.
