Right click & drag is also executing last command
Just upgraded to 7.13.21348.13001, 2021-12-14 and noticing every time I right click & hold to drag, as the usual behaviour, it also executes the last command. Super frustrating. Is this a bug?
I assume you mean right click and hold to pan or tumble the view. I don’t see that happening here (I’m on 7.14 SRC though) however if this was happening across the board I think we would have had a lot of noise in here, which is not the case.
You might want to check your mouse to see if the right button isn’t malfunctioning…
