When i work with Rhino Inside AutoCAD by one reason in AutoCAD disappears all the menu,ribbon,toolsbar,…I could see the geometry screen only. I could have three files open un the same session of AutoCAD and the problems appears in one of that. Do you know some way to fix it?
Hi John,
This should be fixed in V1.0.8, which should be released shortly.
But, in the meantime, you can fix with the CUILOAD command and browse to your: %AppData%\Roaming\Autodesk\ApplicationPlugins\Rhino.Inside.AutoCAD.bundle\Toolbar
and then press load.
