Hi all,
RhinoLands/Lands Design 6.7 is already available for download.
This update is mainly intended to provide compatibility with Rhino 9.
Here is the What’s new list:
Rhino 9 support
Lands Design can now run on Rhino 9, either via the RhinoLands interface or as a regular Rhino plugin.
RhinoLands bundle now includes Rhino 9 instead of Rhino 8.
New “Factory Reset RhinoLands” Windows Start Menu shortcut to launch RhinoLands as if it had never been run on the computer before, restoring all settings to their factory defaults.
New la2View command (analogous to Rhino’s “3View” and “4View” commands) available from RhinoLands Ribbon’s Visualisation tab.
Help
CHM file is now also available in Japanese language.
Error/hang fixes
Ramp object
Corrected rise from angle computation.
Groundcover object
Program hanged when the hatch pattern scale was left empty.
Notes
Supported Rhino versions:
Rhino 9
Rhino 8 SR35 or later
Supported AutoCAD versions:
AutoCAD 2027, 2026, 2025, 2024, 2023, 2022 and 2021
Rhino 7 is no longer supported, users who need to use Rhino 7 can install Lands Design 6.6
One problem: Lands 6.7 is built against Tibidabo 22.1.2.15272, but VisualARQ 3.13 RC2 installs Tibidabo 22.2.0.15284. Since both products share the same core (Common Files\AsuniCAD\Tibidabo\2.0\RHINO9-1), Lands 6.7 crashes Rhino 9 on any Lands command (laFence, laPlant) as soon as VisualARQ 3.13 is installed – access violation in tbdb22.dll.
With VisualARQ 3.12.2 (Tibidabo 22.1.2) everything works, but I need VisualARQ 3.13 for the Rhino 9 named section style support.
Could you please release a Lands Design update built against Tibidabo 22.2, ideally together with VisualARQ 3.13 final (December 2nd)? I’m happy to test a beta.
I think we need to correct the Tibidabo 22.2 included in VisualARQ 3.13 rather than including it in Lands 6.7. In fact, we include Tibidabo 22.1 in Lands 6.7 because it’s more tested and reliable than 22.2.
