I just verified that these files don’t have Created or Edited dates - year, month, day, etc. are all Zero. So, yes, this will throw an exception when you try to access. Knowing this, I would put a try-catch block around your code. If you catch an exception, just use the file system date.
The files you mention are fairly old, but I am a bit surprised they don’t have dates.
Yes this is exactly what I did. I just thought it might be a good idea to make the check in the Created getter. It already does a little validation:
public DateTime Created
get
IntPtr pConstRevisionHistory = UnsafeNativeMethods.ONX_Model_RevisionHistory(this.ConstPointer());
int seconds = 0;
int minutes = 0;
int hours = 0;
int months = 0;
int days = 0;
int years = 0;
if (UnsafeNativeMethods.ON_3dmRevisionHistory_GetDate(pConstRevisionHistory, true, ref seconds, ref minutes, ref hours, ref days, ref months, ref years))
return new DateTime(years, months, days, hours, minutes, seconds);
return DateTime.MinValue;
I’m not expecting a fix, I just thought it was worth mentionning.
Hi Alex,
I just fixed this on github so DateTime.MinValue is returned when no date information exists in these older files. Please note that we are now using a separate branch for Rhino3dmIo on github if you are building from source.
If you are using the nuget packages, this change will show up in our next nuget release.
