RhinoCycles not using RTX 5070 Ti (Desktop) — no GPU tabs appearing
Hi, I’m having an issue where Rhino Render (Cycles) only shows CPU in the device list and won’t use my GPU.
System:
  • Rhino 8 SR32 (8.32.26160.13001)
  • Windows 11
  • NVIDIA GeForce RTX 5070 Ti (Desktop, 16GB VRAM)
  • Driver: 610.62 (June 11 2026)
  • 64GB RAM
What I’ve tried:
  • Updated to latest NVIDIA Studio Driver (610.62)
  • Set Rhino.exe to High Performance GPU in Windows Graphics Settings
  • Rhino’s System Information correctly identifies the 5070 Ti
What happens:
The Rhino Render device settings only shows a CPU tab — no CUDA or OptiX tabs appear at all. CPU usage hits 97% during renders while GPU sits at 2%.
I saw a similar report from a laptop 5070 Ti user (nilceros) where it was assigned to Lars. Is this the same issue affecting desktop cards? Is there a fix or workaround in progress?
surely there has to be right?:sob::crossed_fingers:t3::folded_hands:t2:
Thanks Guys!
Someone said try tagging @lars so here goes nothing​:folded_hands:t2::crossed_fingers:t3::pleading_face:
If you change the category of your post to Rendering and tag @lars you may get lucky :slight_smile:
Thanks for the advice. I just edited the post…
Wish me luck…
I meant the category, not the tag (:
Did I do it right this time?
Better (:
Hi @Nick_Namazian,
could you do the following please:
  1. Send me a Rhino System Report
  2. Close Rhino
  3. Clean install of latest NVIDIA driver (choose Custom install and enable the Clean Install checkbox).
  4. Delete the content of %APPDATA%\McNeel\Rhinoceros\8.0\Plug-ins\RhinoCycles (9bc28e9e-7a6c-4b8f-a0c6-3d05e02d1b97)\data and %APPDATA%\NVIDIA\ComputeCache
Do the CUDA and Optix tabs show up?
Thanks.
-Lars
I am getting this same issue with not being able to ‘see’ the CUDA or Optix tabs using the latest version of NVIDIA (studio) driver on a Dell Inspiron 16 plus 7640. I have eveI disabled the Intel GPU, restarted Rhino and ran SystemInfo and the output doesn’t even identify a CUDA capable device. Were you able to fix your issue?
It would be helpful to see your SystemInfo, even if you cannot see anything obvious.
Hi @lars
I’ve completed all 4 steps:
  1. System Report attached below
  2. Closed Rhino
  3. Clean installed latest NVIDIA Studio Driver (616.92, September 4 2026)
  4. Both folders were already empty (ComputeCache was cleared by the clean install, and the RhinoCycles data folder didn’t exist)
CUDA and OptiX tabs are still not showing — only CPU appears in the device list.
-– SYSTEM INFO —
Rhino 8 SR35 (8.35.26251.13001, 2026-09-08)
Windows 11
NVIDIA GeForce RTX 5070 Ti, 16GB, Driver 616.92 (9-4-2026)
Intel integrated graphics (no monitors attached)
64GB RAM
Rhino 8 SR35 2026-9-8 (Rhino 8, 8.35.26251.13001, Git hash:master @ 3645d710f50175d8ebcf404aded5b042a481c23e)
License type: Educational, build 2026-09-08
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 63GB)
.NET 8.0.21
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 5070 Ti (NVidia) Memory: 16GB, Driver date: 9-4-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 616.92
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port #0
  • Secondary monitor attached to adapter port #1
  • Secondary monitor attached to adapter port #2
Secondary graphics devices.
Intel(R) Graphics (Intel) Memory: 37GB, Driver date: 10-18-2024 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-4-2026
Driver Version: 32.0.16.1692
Z-Buffer depth: 24 bits
Total Video Memory: 16303 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.35.26251.13001
Thanks,
Nick
No unfortunately not yet :frowning:
In Rhino 8 try running the hidden command _RhinoCyclesEnableGPU followed by restarting Rhino. Does that help?
If it works, you can do the same in the WIP if you use it.
HTH
Jeremy
Edit: But update the Intel graphics card driver from the Intel site first, they have been rolling out regular updates of late.
IIRC if GPUs were disabled there would be a button in the rhino render options page to enable the GPUs:
Hi @jeremy5
That worked!!! Running _RhinoCyclesEnableGPU followed by restarting Rhino brought up the CUDA and OptiX tabs and my RTX 5070 Ti is now being used for rendering. GPU usage is up to 45% on a test model which is a massive improvement from the 2% I was getting before.
Thanks so much for the tip and solving the problem!:smiley:
Nick
Hi Marlee,
@jeremy5 found a solution!
Hi Nathan,
No, no such button in 8 or 9, just the hidden commands to enable or disable.
Regards
Jeremy
Funky, those should show up when GPUs have been disabled. There is a disabled file in RhinoCycles settings folder somewhere that controls this.
Thanks Jeremy and Nathan. 2 issues were filed:
RH-98700 and RH-98701.
-Lars
