Hello!
Lately I have been working on a project which utilizes some awesomeness of RhinoCommon along side the Revit API. The purpose is to use RhinoCommon as a more efficient solution for some geometry operations where the Revit API becomes too heavy and memory intensive. So far its been great on Windows 8, but I lately have changed workstations and now am setting up with Windows10 and am discovering some issues.
The error I am getting is with rhcommon_c.dll :
Another error log:
System.DllNotFoundException: Unable to load DLL ârhcommon_câ: A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) at Microsoft.Scripting.Interpreter.NewInstruction.Run(InterpretedFrame frame) at Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame) at Microsoft.Scripting.Interpreter.LightLambda.Run5[T0,T1,T2,T3,T4,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4) at System.Dynamic.UpdateDelegates.UpdateAndExecute4[T0,T1,T2,T3,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2, T3 arg3) at Microsoft.Scripting.Interpreter.DynamicInstruction`5.Run(InterpretedFrame frame) at Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame) at Microsoft.Scripting.Interpreter.LightLambda.Run2[T0,T1,TRet](T0 arg0, T1 arg1) at IronPython.Compiler.PythonScriptCode.RunWorker(CodeContext ctx) at Microsoft.Scripting.Hosting.ScriptSource.Execute(ScriptScope scope) at pyRevitLoader.ScriptExecutor.ExecuteScript(String âŚ
I am using pyRevit which uses IronPython 2.7:
clr.References
- mscorlib, Version=4.0.0.0
- System, Version=4.0.0.0
- IronPython.SQLite, Version=2.7.0.40
- IronPython.Wpf, Version=2.7.0.40
- RhinoCommon, Version=5.1.30000.17
Example:
import sys
import clr
clr.AddReference(âRevitAPIâ)
clr.AddReference(âRevitAPIUIâ)
import Autodesk
from Autodesk.Revit.UI import *
from Autodesk.Revit.DB import *
version = revit.Application.VersionNumber.ToString()
uidoc = revit.ActiveUIDocument
currentView = uidoc.ActiveView
sys.path.append(âC:\Program Files\Rhinoceros 5 (64-bit)\Systemâ)
clr.AddReference(âRhinoCommonâ)
import Rhino as r
import Rhino.Geometry as rg
testPoint = rg.Point3d(1,1,1) #works
print testPoint
testLine = rg.LineCurve(rg.Point3d(0,0,0), rg.Point3d(1,1,1)) #crashes
print testLine
Any advice on this issue? The fact that some classes work and some donât is odd. Is there something that Iâm missing with using RhinoCommon on windows 10? Or am I going in the wrong direction all together?
Any help is much appreciated!
Best,
Brian
