Hi All,
I use C# to make a Rhino plugin in version 8.
When I run the application it have error below. In reference I added this file
Please help me to find solution to fix it!
Thanks
Hi All,
Thanks
how are you running the plugin? it may be helpful to set up a launch profile for your project as here Unable to start Rhino8 from Visual Studio 2022 for debugging - #3 by david.birch.uk
Thank you so much for quick response
In my project folder I do not see file launchSettings.json
Thanks
It looks like you’re referencing the DLL from Rhino’s Folder? I would use the RhinoCommon, Rhino.UI and Eto.Forms Nuget packages if you’re not.
This error can also occur if the dlls are copied into the build directory, which you want to avoid, you can append the Private/PrivateAssets to the import as below
<PackageReference Include="<PackageName>" Version="<Version>" Private="False" PrivateAssets="all" />
Can you try clearing your build folder to ensure the dlls are not in there?
I try clean this folder but this error not done
Please check my project in link below
Dear @dale
Please check in my file in link above
Thanks
Hi @nguyentheta2002,
The RhinoCommon your project is referencing is for us in Rhino plug-ins.
If you want to access Rhino from a standalone .NET application, use Rhino.Inside.
Here are a couple of samples:
RhinoInsideText.zip (3.4 KB)
– Dale
