Rhinocommon copy points and creating a plane
I am trying to create a plane by moving points, but the x-point changes with while creating an y-point.
What am I doing wrong?
Thank you for your response. :slight_smile:
20190202 problem rhinocommon 00.gh (5.0 KB)
Most likely you cannot make a copy with the assignment operator:
copyxpn = xpn # both variables are a reference to the same point-object
It should be something like
copyxpn = xpn.Duplicate()
I tried that before, but it then says
Runtime error (MissingMemberException): 'Point3d' object has no attribute 'Duplicate'
Traceback:
  line 4, in script
Hi @ForestOwl, @menno is right, both references point to the same point. There isn’t a Duplicate method but you can simply create a new point like so copyxpn = rg.Point3d(xpn)
Refer to https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Point3d__ctor.htm
Great! Thank you both :smile:
