For mesh, breps, curves classes, I duplicate objects by writing
Mesh aCopy= a.Duplicate();
For structs such as lines, points, it is enough to write
Point3d aCopy = a;
For Box objects is it also enough to write Box aCopy = a;
or it is must be somehow duplicated as well?
Thanks @AndersDeleuran
Is there a similar approach for Rhino 6 SDK?
Ah yes, no you’re right. I remember coming across this issue as well. My bad.
Hi, I wrote some test codes for Point3d for both C# and Python and the results are interesting.
I want somebody more expert than me to confirm (and explain) this.
In C#,
var X=Transform.Translation(1,0,0);
var p=new Point3d(0,0,0);
var q=p;
p.Transform(X);
Print(p.ToString());
Print(q.ToString());
This gives (1,0,0) and (0,0,0), whilst, in Python,
X=rg.Transform.Translation(1,0,0)
p=rg.Point3d(0,0,0)
q=p
p.Transform(X)
print p
print q
this gives both (1,0,0).
For c# it makes sense because point3d is a Struct. for python there is something else Anders knows what
Structs don’t duplicate by assignment in IronPython like they do in C#. You need to explicitly duplicate them using e.g. the Python copy
module, or the copy constructor if the struct has one (i.e. like Box
has in V7):
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Point3d__ctor.htm
I try to use the explicit RhinoCommon struct option when possible. In the case of translating a point by a vector though I usually use the +=
operator to add the two, which overwrites the value of the original, which negates the assignment copy issue in this case:
Being explicit is probably always advisble though:
Thank you! this is extremely helpful!
