is there a method to make a copy of a Rhino.Collections.Point3dList()?
As far as i understand with Point3dList.CopyTo(…) i just can copy the list to an array.
Or have i to do it this way?:
rhino_points = rc.Collections.Point3dList()
for point in rhino_points_in:
rhino_points.Add(point)
Thank you for you suggestions. I tried them, but both doesn’t work on rhinos Point3dList.
But adding points to a rhino Point3dList seems to be quite fast, so i can use this without serious performance loss.
Have a nice evening!
You can create an instance of a Point3dList from anything that represents an enumerable list of points.
import Rhino
ptlist = Rhino.Collections.Point3dList()
for x in range(10):
for y in range(10):
ptlist.Add(x,y,0)
# create an independent copy of ptlist
copylist = Rhino.Collections.Point3dList(ptlist)
copylist.Add(1,1,1)
print len(ptlist)
print len(copylist)
